This may seem very beginner but I can’t figure out for the life of me how to change the bullet point color from black. When I go into the text stack that includes the bulletpoints to edit the bulletpoints are correct. When I snap back out of editing the text, the bullet points go back to black. Trying to make a dark themed site so black don’t work too well. I know I’ve changed the color in the past on another site but just can’t remember how I did it. Here’s what i’m talkin about…
Hey there, did you get an answer to this? I’m having the same issue, would be lovely to find a fix.
Ok I’m trying that one, i still don’t see where you can change colours though.
It’s in the List Point style in settings. If you choose, for example, Coloured Dot, then you’ll get a colour picker underneath that lets you change the colour of the dot.
@NeilUK is right, it’s a really good stack.
Rob
I use lister
it works great: https://www.lisasandlerphotography.com/details/faq/
Ah brilliant, it works perfectly, thanks everyone
