Can Not Publish Sites
Updated a couple of days ago to Rapidweaver 7.5.5 and I just added a new subdomain today, went to publish and I get an error “Couldn’t sign in to your FTP server.” Checked with my Account Manager, Little Oak, and everything is fine on their end. So I went back to some sites I haven’t touched/published for a few weeks, and they will not publish. None of my sites publish! Is anyone else having this problem. Very frustrating, I don’t know what to do at this point. Any suggestions??
No problems here on 7.5.5 - updated 4 sites to different hosts today.
On one site yesterday, the password had disappeared in the publish settings after upgrading. Once I added that in, everything went back to normal. Doesn’t sound like the same issue your having though…
I had the same problem and contacted Support. They told me to delete the publishing bookmark and add a new version. That worked for me.
Thanks for your help Jeu, I reset my password and that seemed to fix it. (although I think if I did what you suggested that would work also) I was surprised to discover that if you change the password on one project it changes the password on all your projects…
Cheers, Harold
Was able to find a fix the problem, but by the sounds of it, not the only way. I reset my password and that seemed to correct the publishing issue. Something I noticed that I didn’t realize, is when you change the password on one project/website, it changes on all of them? (so if you enter an incorrect password on one, it will change on the others? I think somehow in adding the sub domain, (cutting and pasting) my password was corrupted, either on my side/Rapidweaver or their end.
OK, that’s good to hear.
Jeu
I’m also have problems publishing since upgrading to Version 7.5.5 (18814). Have tried changing the publishing settings and deleting and re-installing the publishing bookmark.
I’m getting multiple “Cant upload to your server (retry in n seconds)” errors. It feels like it is getting there but it has taken about an hour to publish just over 400 (of around 550) files.
I guess my next step is to go back to the prior version, unless anyone has any other suggestions?
Mark
I’ve tried going back to a previous version of Rapidweaver, without success.
I’ve also tried publishing to another host and have the same problem.
Exporting and then uploading with a separate ftp application appears to work ok.
So it looks like there is something in my project that i causing the publishing problem, appreciate any help in identifying where to look.
Mark
Hi Mark,
Hope this helps.
Harold
(by the way, I am pretty sure that when you enter the new password in the one project, it will change them all?)
In the end I saved the project to a new name, tried that, same problem.
Then deleted the pages (there were 8) that I added prior to the problem starting, this fixed the publishing problem.
I then added the pages back from the original project one by one to identify where the problem was. Only thing was I couldn’t find it, all pages added back and publishing perfectly, for now at least.
Regards
Mark
I had a problem publishing a new site using Rapidweaver 7, out of frustration I just exported the files in RW to a directory and then used Filezilla to FTP them to my server. I was able to publish that way. But then after making some minor change, I was able to publish through Rapidweaver. I think it’s just buggy sometimes. My RW crashes kind of a lot too, but I just live with it.
