I have an old website project built with RW3 that now needs updating. However, it won’t open in 5.4.1, which is what I’m currently using. Hesitant to upgrade to 7 until I’ve got a solution. Suggestions? Thanks.
Won’t you have to go via 4 to get to 5 to get to 5.4.1 and thence to 7?
Thanks for the reply. It would be all and good if I had those earlier versions of the software, however all I currently have is 5.4.1. and there appears to be no way to download anything but 7 on the website. Am I missing where to find earlier software? Thanks again.
You should be able to scroll through the release notes here and get an older version: https://www.realmacsoftware.com/rapidweaver/releasenotes/
