Catalina + Rapidweaver plugins
Hi, I just upgraded to Catalina and got the “plugin not codesigned by the developer” message…so I removed those outdated plugins from my RW addons folder.
But I’m still getting the warning message every time I launch RW.
How do I stop RW from giving me this message?
Remove those pages from the project
You need to remove or update the actual plugins (not just the pages) from the RapidWeaver addons manager.
Some are no longer available some need to updated:
Thanks… But I haven’t used those plugins in any projects for many years now…
Is there a database that I need to remove them from? RW seems to think that I still have the plugins, but I’ve deleted them from my machine
Thanks @teefers!
I read that post already and upgraded the plugins that need to be upgraded and removed the old ones… But I’m still getting the warning
Are you sure that RW is pointing to the right addons folder?
Check the addons folder location:
Click on the Reveal in Finder Button (addons manager).
RW on start up I believe just loads the plugins from the addons folder. There is no database.
Thanks Doug! I was able to fix it :slight_smile:
