Hello,
I am working from a Laptop, a good one, having left my hometown to avoid the coronavirus.
I thought I had figured out how to work from a different computer but I am getting a weird message when I start Rapidweaver:
Rapidweaver failed to load some plugins
EasyTubeGallery: Plugin is not codesigned by the developer
Mobilize: Plugin is not codesigned by the developer
RapidBlog: Plugin is not codesigned by the developer
weaverPix: Plugin is not codesigned by the developer
How do I fix this?
thank you and Stay Healthy,
Traci
Your laptop runs Catalina macOS 10.15 I assume? Then you need updates for these plugins which work with Catalina, from the developers…
teefers
(Doug Bennett)
3
I don’t think of those (if not all) are still around, so no Catalina versions.
If you aren’t using these plugins you can delete them.
system
(system)
Closed
4
