Contact Form fails to work
Dear All
I’ve been battling with this problem for some time and it has me beat. I hope someone can shed some light onto a solution.
I’m using Rapidweaver Version 5.3.2 on a MacBook Pro.
Hosting with: one.com
I’ve successfully designed and published a website including the Rapidweaver Contact Form. When someone completes the form correctly and hits the submit button, the email is never received and they are given this response:
I’m sorry, there seems to have been an error trying to send your email. Please try again.
I’m at a total loss at to what to do. Any experts out there have any answers or ideas?
Thank you in advance.
Regards
Phil
I’m afraid that the simple answer is that you must have entered something incorrectly.
Take a second look at the configuration of the form, you may have missed an @ or something similar in the E-Mail you have specified.
Another option would be FormLoom, it’s an awesome plugin dedicated for contact forms - it’s easier and faster to setup in my opinion. There’s a free trial available too, simply google it.
@PhilipM
Perhaps this!
This is a known issue with some hosters.
Not all hosters can properly process the RW contact form plugin.
Some hosters, there is no reaction, in others there is a misrepresentation of the mail form.
Try it with FormLoom, how RWtuts already wrote.
Thanks for all of your suggestions.
I have double checked the email address and details entered in the settings and all appears to be correct. My Host says they support LAMP so I guess it should work.
I am unsure if the following need to be selected although I have tried and it’s made no difference:
Send email using your email address
Define email address in PHP mail script
I will give the free trial of Formloom a go as suggested. Thanks again.
