Container line stack
Hi, I’m building a site with foundry. I used container with slides inside it, only that, on the construction page, the container line appears but I no longer see the slide stack. How can I do to open the container line?
Elixir does answer threads here but you might get a faster response at
@rolisize – That is definitely not the case. I’m faster to reply on the Elixir forum, as I check it far more, but I do answer here as well.
As for @claudiope’s question – I’m not sure I understanding what you’re asking. Do you have a project file you can share with us so we can see what you’re referring to? That and some screenshots would help. I don’t suspect this is a bug or problem, but sound more like growing pains of learning something new, so I suspect either myself or someone here will be able to set you on the right path forward.
I solved: I had hidden the container by mistake from the command bar. Thanks for the answers.
Glad to hear you got it sorted. Always feels good to discover it, right?! That eureka moment feels good.
