Hi and thanks for any assistance,
Im using RW 6.4 and transmit 4.4.13. both the latest versions.
My mac (a 2009 iMac) has OS 10.9.5.
I am trying to upload a website to my host (little oak)and it is saying “could not change directory to … server said no such files or directory… error .125” then i am getting “files not uploaded…some errors were encountered…dbl check settings…”.
I tried a few different simple things but no luck.
Are you a regular user of Transmit and uploading files to this server? It sounds like your login info is wrong but then you also sound like you are a long time user. Why not put your ftp credentials into RW and “test” to see what you get. The nice thing about RW is you can just right click and publish single pages (assuming nothing global changed on page.) You really should at least try RW publishing (uploading.)
Hi Greg,
Yes ive been using transmit i since i first got into RW4. But i havent progressed much since then other than upgrading and im now with RW6. I have about 12 web sites up, but they are all pretty straightforward. I seem to work on one for a few days every 6 months or so. A few months ago i worked on one of my sites and it uploaded correctly. So my log ins are all OK. But on your advice ill have a look at publishing from RW and see what happens. Thanks
