Crash when I open RW
Hello, I would appreciate any help a lot. Every time I try to start RW it crashes after 5 seconds runtime. I have absolutely no idea what to do …
Process: RapidWeaver 6 [4004]
Path: /Applications/RapidWeaver 6.app/Contents/MacOS/RapidWeaver 6
Identifier: com.realmacsoftware.rapidweaver6
Version: 6.3.7 (15153)
Code Type: X86-64 (Native)
Parent Process: ??? [1]
Responsible: RapidWeaver 6 [4004]
User ID: 502
Date/Time: 2016-04-06 10:04:56.564 +0200
OS Version: Mac OS X 10.11.4 (15E65)
Report Version: 11
Anonymous UUID: F3CAA6F2-C2D5-3C5E-3E37-9BC59A2E547B
Sleep/Wake UUID: 8FA47F07-26B3-4031-946B-C8515C4664FB
Time Awake Since Boot: 20000 seconds
Time Since Wake: 4000 seconds
System Integrity Protection: enabled
Crashed Thread: 12
Exception Type: EXC_GUARD
Exception Codes: 0x4000000200000001, 0x08fd4dbfade2dead
@APro
I would suggest that you download the full version of RW 6.3.8 here, install it overtop of Rw 6.3.7 and see if that resolves the issues.
The only other thing I can think of is do you have any disk cleaning utilities installed, those are known to cause issues with RapidWeaver.
Lastly, what did you install prior to the issue happening?
Hope that helps in some little way
Brad
Thank you so much Turtle. Seems as if it works with an overtop installation! You made my day :grin:
@APro
Thanks for updating the forum issue is resolved :slight_smile:
Glad to be of assistance and have an awesome day!
Brad
