CSS not loaded after updating to RW8
I just updated to RW8 from RW7.5.5. For one project only the CSS doesn’t load after updating the project. For both the preview mode and when doing a preview in Safari. That makes working with the project pretty slow.
I’m using Foundation and Total CMS from Joe Workman and a few other stacks.
Does anyone have an idea what might be wrong here? I’ve got another project that loads fine. This one also uses Foundation, but not Total CMS.
Problems with CSS:
CSS loading:
Bummer. Now RW7.5.5 shows the same problem. Must be me and not RW.
In the preview I see at the bottom:
Your Foundation Stacks are out of date. Please update to version v. ×
Your Foundation Theme is out of date. Please update to version v.
Download the latest theme from Foundation 6 Stacks for RapidWeaver. ×
Foundation theme not applied! Please set the Foundation theme as the theme for this project. ×
Duplicate Pages Found on Your Server
Foundation has detected 2 versions of this webpage on the server:
You can use the buttons to easily choose which file to remove form the server. You can also use your favorite FTP program to do this as well.
Remove HTML File Remove PHP File ×
But I’m local here and not on the server. How do I solve these error messages?
Regards
Beatrix Willius
The foundation theme and stacks will all update on your local machine, not on the server.
When you say you are local and not on the server what do you mean? Are you not publishing the site somewhere? You must have been at some stage because RW has published 2 versions of the page to a web server and you need to remove one of them (almost certainly the html.index version)
The website is at www.mothsoftware.com. This works fine. I’ve also checked that there are no duplicate index files on the server.
It’s just the preview in Rapidweaver that doesn’t work. It seems that no theme is applied to the project - but only for the preview. I’ve tried to reapply the theme but no dice.
I’ve had computer trouble in the second half of August. The computer was updated from El Capitan to Sierra. I think the last time I worked with Rapidweaver was before this.
I checked that the theme and the stacks are installed okay.
OK - I see. Sounds like a RW support issue. Have you tried re-installing Rapidweaver?
I’ve moved everything to another computer and there I get the same problem.
Could this be a sandboxing issue? I’ve also deleted what I could find from Rapidweaver in private/var/folders. Anything else I could delete? I’ve already restarted the computer.
Should I send project files to Rapidweaver support?
And here is the console output when doing a preview:
standard 12:41:42.076728 +0200 RapidWeaver 8 TIC TCP Conn Cancel [11:0x600003d2b3c0]
standard 12:41:42.077503 +0200 RapidWeaver 8 [C11 Hostname#87834179:443 tcp, url: https://updates.joeworkman.net/appcast.php?StackAPIVersion=10&StackID=com.bigwhiteduck.stacks.sections_pro.borders.maste, tls] cancel
standard 12:41:42.078181 +0200 RapidWeaver 8 [C11 Hostname#87834179:443 tcp, url: https://updates.joeworkman.net/appcast.php?StackAPIVersion=10&StackID=com.bigwhiteduck.stacks.sections_pro.borders.maste, tls] cancelled
[C11.1 2003:e3:9f30:8871:6da6:1ebd:728e:e6c6.50117<->IPv6#a6050f4e.443]
Connected Path: satisfied (Path is satisfied), interface: en0, ipv4, ipv6, dns
Duration: 67.511s, DNS @0.000s took 0.029s, TCP @0.030s took 0.033s, TLS took 0.035s
bytes in/out: 6482/13534, packets in/out: 15/15, rtt: 0.036s, retransmitted packets: 0, out-of-order packets: 0
standard 12:41:42.078289 +0200 RapidWeaver 8 0.000s [C11 Hostname#87834179:443 resolver] path:start
standard 12:41:42.078322 +0200 RapidWeaver 8 0.000s [C11 Hostname#87834179:443 resolver] path:satisfied
standard 12:41:42.078354 +0200 RapidWeaver 8 0.000s [C11 Hostname#87834179:443 resolver] resolver:start_dns
standard 12:41:42.078400 +0200 RapidWeaver 8 0.029s [C11 Hostname#87834179:443 resolver] resolver:receive_dns
standard 12:41:42.078469 +0200 RapidWeaver 8 0.029s [C11.1 2003:e3:9f30:8871:6da6:1ebd:728e:e6c6.50117<->IPv6#a6050f4e.443 socket-flow] path:start
standard 12:41:42.078514 +0200 RapidWeaver 8 0.029s [C11.1 2003:e3:9f30:8871:6da6:1ebd:728e:e6c6.50117<->IPv6#a6050f4e.443 socket-flow] path:satisfied
standard 12:41:42.078557 +0200 RapidWeaver 8 0.030s [C11.1 2003:e3:9f30:8871:6da6:1ebd:728e:e6c6.50117<->IPv6#a6050f4e.443 socket-flow] flow:start_connect
standard 12:41:42.078601 +0200 RapidWeaver 8 0.063s [C11.1 2003:e3:9f30:8871:6da6:1ebd:728e:e6c6.50117<->IPv6#a6050f4e.443 socket-flow] flow:finish_transport
standard 12:41:42.078646 +0200 RapidWeaver 8 0.063s [C11 Hostname#87834179:443 resolver] flow:finish_transport
standard 12:41:42.078692 +0200 RapidWeaver 8 0.098s [C11.1 2003:e3:9f30:8871:6da6:1ebd:728e:e6c6.50117<->IPv6#a6050f4e.443 socket-flow] flow:finish_connect
standard 12:41:42.078735 +0200 RapidWeaver 8 0.098s [C11 Hostname#87834179:443 resolver] flow:finish_connect
standard 12:41:42.078783 +0200 RapidWeaver 8 0.098s [C11.1 2003:e3:9f30:8871:6da6:1ebd:728e:e6c6.50117<->IPv6#a6050f4e.443 socket-flow] flow:changed_viability
standard 12:41:42.078829 +0200 RapidWeaver 8 0.098s [C11 Hostname#87834179:443 resolver] flow:changed_viability
standard 12:41:42.078925 +0200 RapidWeaver 8 67.511s [C11] path:cancel
standard 12:41:42.082029 +0200 RapidWeaver 8 nw_endpoint_flow_protocol_disconnected [C11.1 IPv6#a6050f4e.443 cancelled socket-flow (null)] Output protocol disconnected
standard 12:41:42.082406 +0200 RapidWeaver 8 nw_connection_report_state_with_handler_locked [C11] reporting state cancelled
standard 12:41:42.082461 +0200 RapidWeaver 8 TIC TCP Conn Cancel [18:0x600003d2bd80]
standard 12:41:42.082654 +0200 RapidWeaver 8 [C18 Hostname#87834179:443 tcp, url: https://updates.joeworkman.net/appcast.php?StackAPIVersion=10&StackID=com.bigwhiteduck.stacks.sections_pro.borders&Stack, tls] cancel
standard 12:41:42.082904 +0200 RapidWeaver 8 [C18 Hostname#87834179:443 tcp, url: https://updates.joeworkman.net/appcast.php?StackAPIVersion=10&StackID=com.bigwhiteduck.stacks.sections_pro.borders&Stack, tls] cancelled
[C18.1 2003:e3:9f30:8871:6da6:1ebd:728e:e6c6.50124<->IPv6#a6050f4e.443]
Duration: 67.416s, DNS @0.000s took 0.013s, TCP @0.015s took 0.035s, TLS took 0.036s
bytes in/out: 4021/8144, packets in/out: 10/10, rtt: 0.036s, retransmitted packets: 0, out-of-order packets: 0
standard 12:41:42.082943 +0200 RapidWeaver 8 0.000s [C18 Hostname#87834179:443 resolver] path:start
standard 12:41:42.082971 +0200 RapidWeaver 8 0.000s [C18 Hostname#87834179:443 resolver] path:satisfied
standard 12:41:42.082994 +0200 RapidWeaver 8 0.000s [C18 Hostname#87834179:443 resolver] resolver:start_dns
standard 12:41:42.083094 +0200 RapidWeaver 8 0.013s [C18 Hostname#87834179:443 resolver] resolver:receive_dns
standard 12:41:42.083165 +0200 RapidWeaver 8 0.014s [C18.1 2003:e3:9f30:8871:6da6:1ebd:728e:e6c6.50124<->IPv6#a6050f4e.443 socket-flow] path:start
standard 12:41:42.083250 +0200 RapidWeaver 8 0.014s [C18.1 2003:e3:9f30:8871:6da6:1ebd:728e:e6c6.50124<->IPv6#a6050f4e.443 socket-flow] path:satisfied
standard 12:41:42.083343 +0200 RapidWeaver 8 0.015s [C18.1 2003:e3:9f30:8871:6da6:1ebd:728e:e6c6.50124<->IPv6#a6050f4e.443 socket-flow] flow:start_connect
standard 12:41:42.083509 +0200 RapidWeaver 8 0.050s [C18.1 2003:e3:9f30:8871:6da6:1ebd:728e:e6c6.50124<->IPv6#a6050f4e.443 socket-flow] flow:finish_transport
standard 12:41:42.083579 +0200 RapidWeaver 8 0.050s [C18 Hostname#87834179:443 resolver] flow:finish_transport
standard 12:41:42.083654 +0200 RapidWeaver 8 0.086s [C18.1 2003:e3:9f30:8871:6da6:1ebd:728e:e6c6.50124<->IPv6#a6050f4e.443 socket-flow] flow:finish_connect
standard 12:41:42.083729 +0200 RapidWeaver 8 0.086s [C18 Hostname#87834179:443 resolver] flow:finish_connect
standard 12:41:42.083825 +0200 RapidWeaver 8 0.086s [C18.1 2003:e3:9f30:8871:6da6:1ebd:728e:e6c6.50124<->IPv6#a6050f4e.443 socket-flow] flow:changed_viability
standard 12:41:42.083883 +0200 RapidWeaver 8 0.086s [C18 Hostname#87834179:443 resolver] flow:changed_viability
standard 12:41:42.083962 +0200 RapidWeaver 8 67.416s [C18] path:cancel
standard 12:41:42.084624 +0200 RapidWeaver 8 nw_endpoint_flow_protocol_disconnected [C18.1 IPv6#a6050f4e.443 cancelled socket-flow (null)] Output protocol disconnected
standard 12:41:42.085351 +0200 RapidWeaver 8 nw_connection_report_state_with_handler_locked [C18] reporting state cancelled
standard 12:41:42.085463 +0200 RapidWeaver 8 TIC TCP Conn Cancel [19:0x600003d28240]
standard 12:41:42.085639 +0200 RapidWeaver 8 [C19 Hostname#87834179:443 tcp, url: https://updates.joeworkman.net/appcast.php?StackAPIVersion=10&StackID=com.bigwhiteduck.stacks.sections_pro.background.ma, tls] cancel
standard 12:41:42.085913 +0200 RapidWeaver 8 [C19 Hostname#87834179:443 tcp, url: https://updates.joeworkman.net/appcast.php?StackAPIVersion=10&StackID=com.bigwhiteduck.stacks.sections_pro.background.ma, tls] cancelled
[C19.1 2003:e3:9f30:8871:6da6:1ebd:728e:e6c6.50125<->IPv6#a6050f4e.443]
Duration: 67.416s, DNS @0.000s took 0.009s, TCP @0.013s took 0.034s, TLS took 0.036s
bytes in/out: 3519/7201, packets in/out: 8/9, rtt: 0.040s, retransmitted packets: 0, out-of-order packets: 0
standard 12:41:42.085961 +0200 RapidWeaver 8 0.000s [C19 Hostname#87834179:443 resolver] path:start
standard 12:41:42.086000 +0200 RapidWeaver 8 0.000s [C19 Hostname#87834179:443 resolver] path:satisfied
standard 12:41:42.086038 +0200 RapidWeaver 8 0.000s [C19 Hostname#87834179:443 resolver] resolver:start_dns
standard 12:41:42.086074 +0200 RapidWeaver 8 0.009s [C19 Hostname#87834179:443 resolver] resolver:receive_dns
standard 12:41:42.086114 +0200 RapidWeaver 8 0.012s [C19.1 2003:e3:9f30:8871:6da6:1ebd:728e:e6c6.50125<->IPv6#a6050f4e.443 socket-flow] path:start
standard 12:41:42.086153 +0200 RapidWeaver 8 0.012s [C19.1 2003:e3:9f30:8871:6da6:1ebd:728e:e6c6.50125<->IPv6#a6050f4e.443 socket-flow] path:satisfied
standard 12:41:42.086190 +0200 RapidWeaver 8 0.013s [C19.1 2003:e3:9f30:8871:6da6:1ebd:728e:e6c6.50125<->IPv6#a6050f4e.443 socket-flow] flow:start_connect
standard 12:41:42.086300 +0200 RapidWeaver 8 0.047s [C19.1 2003:e3:9f30:8871:6da6:1ebd:728e:e6c6.50125<->IPv6#a6050f4e.443 socket-flow] flow:finish_transport
standard 12:41:42.086367 +0200 RapidWeaver 8 0.047s [C19 Hostname#87834179:443 resolver] flow:finish_transport
standard 12:41:42.086447 +0200 RapidWeaver 8 0.083s [C19.1 2003:e3:9f30:8871:6da6:1ebd:728e:e6c6.50125<->IPv6#a6050f4e.443 socket-flow] flow:finish_connect
standard 12:41:42.086517 +0200 RapidWeaver 8 0.083s [C19 Hostname#87834179:443 resolver] flow:finish_connect
standard 12:41:42.086586 +0200 RapidWeaver 8 0.083s [C19.1 2003:e3:9f30:8871:6da6:1ebd:728e:e6c6.50125<->IPv6#a6050f4e.443 socket-flow] flow:changed_viability
standard 12:41:42.086668 +0200 RapidWeaver 8 0.083s [C19 Hostname#87834179:443 resolver] flow:changed_viability
standard 12:41:42.086736 +0200 RapidWeaver 8 67.416s [C19] path:cancel
standard 12:41:42.087346 +0200 RapidWeaver 8 nw_endpoint_flow_protocol_disconnected [C19.1 IPv6#a6050f4e.443 cancelled socket-flow (null)] Output protocol disconnected
standard 12:41:42.087911 +0200 RapidWeaver 8 nw_connection_report_state_with_handler_locked [C19] reporting state cancelled
standard 12:41:43.283985 +0200 loginwindow -[PersistentAppsSupport saveLogoutPersistentState:finalSnapshot:] | previouslyRunningApps: (
BackgroundState = 0;
BundleID = “com.realmacsoftware.rapidweaver8”;
Hide = 0;
Path = “/Applications/RapidWeaver 8.app”;
BackgroundState = 2;
BundleID = “com.apple.finder”;
Hide = 0;
Path = “/System/Library/CoreServices/Finder.app”;
BundleID = “com.apple.safari”;
Hide = 1;
Path = “/Applications/Safari.app”;
BundleID = “org.tempel.findanyfile”;
Hide = 1;
Path = “/Applications/Find Any File.app”;
BundleID = “com.apple.mail”;
Hide = 1;
Path = “/Applications/Mail.app”;
BackgroundState = 3;
BundleID = “com.xojo.xojo”;
Hide = 1;
Path = “/Applications/Xojo/Xojo.app”;
BundleID = “com.apple.textedit”;
Hide = 1;
Path = “/Applications/TextEdit.app”;
BundleID = “com.apple.iwork.pages”;
Hide = 1;
Path = “/Applications/Pages.app”;
BundleID = “com.wunderkinder.wunderlistdesktop”;
Hide = 1;
Path = “/Applications/Wunderlist.app”;
standard 12:41:43.299113 +0200 loginwindow -[PersistentAppsSupport saveLogoutPersistentState:finalSnapshot:] | checkAgainstApp is : RapidWeaver
standard 12:41:43.299135 +0200 loginwindow -[PersistentAppsSupport appShouldBeRelaunched:] | entered. checking app: RapidWeaver
standard 12:41:43.299174 +0200 loginwindow -[PersistentAppsSupport saveLogoutPersistentState:finalSnapshot:] | Adding to relaunchArray: RapidWeaver
standard 12:41:43.312610 +0200 loginwindow -[PersistentAppsSupport saveLogoutPersistentState:finalSnapshot:] | Contents:(
BundleID = “com.apple.console”;
Hide = 0;
Path = “/Applications/Utilities/Console.app”;
Hide = 0;
Hide = 0;
Hide = 0;
Hide = 1;
Hide = 1;
Hide = 1;
Hide = 1;
Hide = 1;
Hide = 1;
standard 12:41:57.681893 +0200 RapidWeaver 8 -[MyDocument(PageExport) exportPage:subPagePath:toDirectory:inRoot:usingName:includingChildren:mode:onBackgroundThread:completionBlock:] page=<RWPage 0x600003c42890>: 404page, enabled = 1
standard 12:41:57.682126 +0200 RapidWeaver 8 -[MyDocument(PageExport) exportPage:subPagePath:toDirectory:inRoot:usingName:includingChildren:mode:onBackgroundThread:completionBlock:] subPagePath=(null)
standard 12:41:57.682264 +0200 RapidWeaver 8 -[MyDocument(PageExport) exportPage:subPagePath:toDirectory:inRoot:usingName:includingChildren:mode:onBackgroundThread:completionBlock:] exportLocation=/var/folders/5x/j788v7913kjchhjtnhxmrwvh0000gn/T/com.realmacsoftware.rapidweaver8/RapidWeaver/924/document-0x6000034bb300/RWDocumentPagePreview/errors/404
standard 12:41:57.682403 +0200 RapidWeaver 8 -[MyDocument(PageExport) exportPage:subPagePath:toDirectory:inRoot:usingName:includingChildren:mode:onBackgroundThread:completionBlock:] exportRoot=/var/folders/5x/j788v7913kjchhjtnhxmrwvh0000gn/T/com.realmacsoftware.rapidweaver8/RapidWeaver/924/document-0x6000034bb300/RWDocumentPagePreview
standard 12:41:57.682578 +0200 RapidWeaver 8 -[MyDocument(PageExport) exportPage:subPagePath:toDirectory:inRoot:usingName:includingChildren:mode:onBackgroundThread:completionBlock:] exportName=index.php
standard 12:41:57.682714 +0200 RapidWeaver 8 -[MyDocument(PageExport) exportPage:subPagePath:toDirectory:inRoot:usingName:includingChildren:mode:onBackgroundThread:completionBlock:] descend=0
standard 12:41:57.682820 +0200 RapidWeaver 8 -[MyDocument(PageExport) exportPage:subPagePath:toDirectory:inRoot:usingName:includingChildren:mode:onBackgroundThread:completionBlock:] mode=preview
standard 12:41:57.682957 +0200 RapidWeaver 8 -[MyDocument(PageExport) exportPage:subPagePath:toDirectory:inRoot:usingName:includingChildren:mode:onBackgroundThread:completionBlock:] siteBaseURL=http://www.mothsoftware.com/
