Foundary paragraph stack
in foundary i add paragraph stack and then i want the text to white i can see and choose in page inspector color pick but the result i mean the text is black result why? anyone can help me
Hi there @ognali – Can you do me a favor and send me a ZIP file containing your project file so I can look at your settings? I suspect you’ve simply got something mis-configured as I regularly use the Paragraph stack with various colors.
Here it is.
(Attachment Ognalinew.zip is missing)
how do i attach zip file . i try by email it says cant send this file
Best bet would be to put the file on something like Dropbox, and paste a link to the file on the forum. You might want to do that via a private message to Adam if you don’t want others to be able to download the file.
Just select Adams icon above and hit message.
You’ll need to login to the forum in your browser instead of submitting your reply via email. When you do, you can send me a Direct Message on the forum with a download link, using something like Dropbox, or a similar service of your choice.
is there is any other way to chat with you?
Sure, you can send me a Direct Message here on the forum, you can email me (adam at elixirgraphics dot com), you can visit my website and submit a support ticket through the Support page, or post on the Elixir forum.
