Foundation 6 install issues
Just so people know – I also posted this on Weaverspace.com just because I wasn’t sure which forum would get an answer quicker.
https://community.weavers.space/content/perma?id=155374
The post is as follows (or you can answer on weavers.space):
Having an issue with my Foundation 6 install. (So sorry for the long post.)
So, whenever I check for updates on my stacks, if there are any Foundation updates and I click on “update”, they start Ok, but stall and never finish.
I was watching one of Joe’s videos the other day and his installation for Foundation 6 - stacks and templates - never resembled my install. I don’t see any of the templates, etc.
So in an effort to try to fix this, I went to my Preferences in RW and deactivated anything to do with Foundation (both 1 and 6). Then quite RW and actually removed those items from my RW adding folder. Re-started RW and no mention of Foundation anywhere (so far so good).
I then installed the Foundation 6 theme — RW said it was already installed and was either newer or same version as what I was trying to install. It shouldn’t be as I totally deleted it from the adding folder. Well, I told it to install anyway. Then restarted.
I then moved on to the F6 stacks. Installed those to RW and got the same reply as with the theme — F6 is already installed (same version or newer). I installed anyway. Restarted again.
Moved on to the F6 templates - stalled those and got the same as above.
Now, after all that, if I create a new Stacks page then click on my stacks and search for Foundation, I get nothing showing up.
I’ve done this 3 times already and get the same results.
Am I doing something wrong? Is there a better way to uninstall all the F6 stuff so it will install correctly?
Any help is greatly appreciated.
Thank you, Paul
So, just so everyone knows - Joe is working with me on the weavers.space forum.
I know its early for him out there so I appreciate that.
Paul
