I was having a look at joe Workman’s Parallax and 1LD’s stack and they both look good. Has anyone had experience using both of these that can give a comparison?
Which stack did you end up using Jason?
Do you have parallax working on any sites that I could take a look at?
I ended up using Joe’s, though the site has since been re-worked a bit and is just using fixed image backgrounds (via Sectiins Pro) instead.
Thanks. I bought Joe’s Parallax as well.
I’ll let you know how it goes.
