Foundation Side Nav Menu
Hi -
I’m new to RapidWeaver and am using Stacks with Foundation. I’ve currently using Foundation’s Side Nav Menu. I’d like to have sub-menu items hide and display rather than always be visible (i.e. disclose when the parent menu item is selected and hide when the user selects another menu item).
Is it possible to achieve this and if so how?
Is there an existing component I should be using instead of Side Nav Menu?
thanks in advance
Simon
Right now, there is no way with out coding it yourself. That might change in the future, but not right now.
