soccerdoc
(John Duldner)
1
hello
had a page was working on before Foundry 3 before Elixir Grahics exited (which is a HUGE loss to RW).
anyway have a few pages with the Form tool and these are not publishing:
this is the error message:
# Not Found
The requested URL was not found on this server.
Additionally, a 404 Not Found error was encountered while trying to use an ErrorDocument to handle the request.
would be obliged for any help
ToF
(Torsten Fischer)
2
Hello, remember the form-pages use .php I think. Otherwise I need more information (link, …).
soccerdoc
(John Duldner)
3
Hallo Torsten,
the site is:
www.customcarvingcreations.com
i would assume the Foundry tool would handle that if it used PHP
Thanks for looking
ToF
(Torsten Fischer)
4
our named the folder Get In Touch. Try: getintouch without spaces or get-in-touch
soccerdoc
(John Duldner)
5
hello,
put dashes in for the name pages, but still not showing
ToF
(Torsten Fischer)
6
if you copy the URL on your get in touch page, what do you paste?
ToF
(Torsten Fischer)
8
if you go to: Settings > Publishing an press Test do you get Connection Test Successful?
Did you make any changes on the .htaccess file?
soccerdoc
(John Duldner)
9
soccerdoc
(John Duldner)
10
hello
indeed Test Connection Success each time
no i have made no changes to the .htaccess file
soccerdoc
(John Duldner)
11
Hallo Torsten,
i made the changes in the settings and renamed
all the folders with lower case
i am going to try and delete all the files in my public_html folder and reupload
ToF
(Torsten Fischer)
12
If you put it in public_html folder
Is the Settings > Publishing Path “public_html”?
When you click on Browse do you see the folder?
Anyway you use https you should put it also https in the General and Publishing settings.
ToF
(Torsten Fischer)
13
I took a look at our Sitemap. Only .php do not work the .html sites work. Maybe you should take a look at your settings at your Host or ask them.
soccerdoc
(John Duldner)
14
hallo Torsten
will inquire with hosting platform.
