Foundry Reveal & BWG Sections Stacks Not Working In RW8
Converted an RW7 Site to RW8 and the content inside Foundry Reveal & BWG Sections Stacks isn’t showing in preview mode or on publishing. Scroll down button in Foundry Banner stack not working either.
Hey there @kdjkn –
I just build a quick test of the Foundry Banner stack, in Hero mode, using the scroll down button and all seems to be working A-OK here in RapidWeaver v8. Here’s a quick video showing what I see: https://d.pr/v/Ajgc7o
Perhaps you’ve got a conflict of some wort on your page. Build a quick test page, or use this one I made, using just basic Foundry stacks to see if you’re having the problem with only the Banner stack or if it might be a conflict with another addon that is causing your problem.
Addendum – I forgot you all mentioned Reveal in your original post, so I added Reveal to this test page as well. I’m not seeing any problems with it in RW 8 either. Download this test project or build your own and let me know the results: https://d.pr/f/qfW4IQ
@Elixir I’m wondering if it’s on converted RW7 to RW8 projects? (I mean it shouldn’t be, but that’s the only thing I can think of right now).
And by “converted” you mean an RW7 project that is opened in RW8 — then exported and saved from there. Correct?
Or is there some more explicit “covert” procedure?
I just recreated the same page in RW 7, then loaded it in RW 8 and it works as expected. Here’s the RW 7 project file if anyone wants to use it as a test: https://d.pr/f/XUs5Ay
So @Fuellemann sent me a project file as a test, that also did not work for me. I turned off Minify CSS & Javascript in the Advanced settings and things began functioning again. Odd thing is, in my test projects, both the one created in RW 8 and the one imported from RW 7 into RW 8, have this setting enabled and function as they should.
Thanks Adam. To turn off Minify CSS & Javascript in the Advanced settings was the solution for me. Now it might be for you and @dan to see why this happend. Please tell me if you need any other versions of my testfiles…
Thanks again,
Jan
Send those projects to Dan, please if you will.
RW8 and Foundry working perfectly fine for me. I use Banner a lot with scroll down button. Zip problems on preview or publish. Not using BWG Sections Stacks though.
As advised I turned off Minify CSS & Javascript and as if by magic, the site worked properly. Bit of a bug there guys.
Okay, so that workaround works for now, but we’ll be issuing a new build of RapidWeaver 8 later today that will fix this and a few of the other minor issues that have cropped up today!
Stay tuned, we got this :slight_smile:
Cheers
Dan
Thanks Dan. You guys are on the ball! :smiley:
