I’ve spent hours, but think I found the cause of my problem with RW7. Here Goes:
Problem: When publishing a page, the header image and some H1 formatting gets totally munched.
Background: Converting a file from RW6 to RW7 creates this problem. There is absolutely nothing else that is changing. But when I publish the same file from RW7, it does not appear the same.
I believe the problem is here: When converting the RW project file into RW7, the analytics code is being duplicated into BOTH the header and the body. Same code in both places. But it gets worse:
- Removing all the code, from both places, doesn’t fix the problem. When I republish the entire project, RW still has all the analytics code. It’s like RW7 gave the ‘code’ section a lobotomy.
Can anyone else reproduce this? Try this: Remove your analytics code and publish DIRECTLY the your host (this problem does not exist if I publish locally). Is the code still there?
Thx!
