RW 7.3 - Oh Cr@@@@
Just updated to RW7.3,
Published a site that was working fine using it this morning and now the theme seems shot to bits.
Can some one have a look at it and tell give me an idea of where to start to fix this!! Not sure where the problem is!!!
thanks
www.thehorsephysio.co.uk
A good start is to re-publish the whole site.
I have republished.
I’m just in the processing of downgrading to the previous RW version and republishing to see if that hits the nail or not.
Hi @SimonPalmer,
It looks like you’ve included your Google Analytics code in the Head section of the “Code” settings view - is that right?
I’d go back there and take a look at it - it looks like you’re missing a closing </script> tag. That might not be the only thing, but it’s the first thing I spotted - will take a closer look at your site now.
Yep, once that </script> tag is re-added, everything works correctly:
Hi Simon,
Can I marry you?!!? :slight_smile:
Fixed it, I’ll stop my amateurish panic now.
Cheers and thanks a lot
Simon
LOL :blush:
