Having bought the very interesting Article stack, it will not accept any stack in it.
How do I get content in it???
Open the sample file that came with stack.
Select the article stack
Uncheck collapse content in edit mode.
You then see the dropzone to drop content.
In the sample file they use markdown, select it and delete
and then you should see the “Drop stack here” box
Thanks Rollsize for your quick response, reinstalling solved all problems, working as a charme now.
