I’ve heard the upgrade to MacOS High Sierra that there were some compatibility issues with RW. If so, has Realmac fixed that yet?
According to the release notes, version 7.5.1 brought full compatibility with High Sierra.
I’ve been using HS since its release and I’ve had no issues with RW.
Hi! I am using High Sierra and can confirm that RW works well. Just, make sure you got version that supports High Sierra
I’ve had no problems with RW and High Sierra. I believe that there were issues with the beta version of High Sierra, but these were sorted before High Sierra was officially released.
