How to publish using Transmit?
How to I publish a blog using Transmit? RW6 will not publish
What version of RapidWeaver?
Is it failing to publish at all or just blog pages?
If using 6.3.8 and built in Blog Page Type then this is a known issue and you can contact support@realmacsoftware.com for a possible fix in progress…
Otherwise, export (not publish) your site to a folder, use Transmit to connect via FTP to your host, transfer exported folder contents to server www location…
Brad
Thanks I will do that!
