Hello - I’m using basic styled text pages in RW 7
and have separated areas with a simple
horizontal rule.
I would like the weight or line thickness to be thicker ( more of a heavy line weight ) .
Is there a way to do this ? Customize the line weight so it’s more prominent ?
How are you currently doing rules? You can customize via html code (just google “html rule” and check the examples). If you are using Stacks there are stacks you can use, such as this one: https://stacks4stacks.com/rulestack/index.php
