I just upgrade to Rapid Weaver 8. I have now a problem with a page a made with partitions. It can not be used in 8. Still i have a page that i have to rebuild in 8. Can you give a good suggestion with what kind of stack or addon i can use to get a good copy of it? Did try to use Stack but i didn’t manage it.![]()
Shall try to send a picture of the page i am writing about.
I hope you can help me!
Maybe Table Pro by Cosculture https://www.cosculture.com/plugins-stacks/product/table-pro/ would do what you want.
Richard
Thanks Richard, i take a good look at table-pro and i think it will have not more place than 5 columns and i really need 7! So i will look further.
Thanks again for your tip!
Try @joeworkman Power Grid CSV stack
http://www.ibize.com/Backyardflyer/CulverProps/
This stack is very good and there’s a free demo so you can try it out.
Thanks Joe, i was also trying the tip of Rob, and it seems that this will do what i neeed
Thanks Rob, i am now very busy with your tip table builder. I thing this will do the job! So thanks a lot!
Good stuff. I think it’s a really good stack.
Rob
