I’m using Reason Pro to rebuild a site. I’m having trouble with text and images on the Index page. Although the text is Centre Aligned, it becomes Right Aligned in Preview. Similarly the ‘link icons’. See screen grab. I would like the BLUE text and ‘link icons’ below to be centred. Am I asking too much? Where am I going wrong?
Edit mode:
Did you write the text in Rapidweaver or copy/paste from some other app? If the latter, it’s important to strip all formatting before pasting into Rapidweaver so there’s not conflict of format.
Brian, I had an inkling that would be a problem so I formatted the text to Simple Text and pasted it into RW. Should I delete it and just re-type it?
Cheers
Brad
Try pasting it with “Paste as Plain Text” (option+comand+v ). That would eliminate any formatting being carried over from Simple Text, as Brian mentioned.
