I had an issue with Map 2 in October which was resolved and my maps displayed correctly. Today I went to do some updates on the site and once again am getting an error message. I haven’t changed anything. I’ve emailed Gary at Doobox, however I’m posting here
in case I’ve missed an update of some sort. It’s for a home builder site which relies heavily on maps and directions: patcohomes.comLooks like you got it fixed?
I wish! No that’s the site now. Last edits from October. Working on update now in RW which I opened this morning and the maps are gone again so can’t publish my updates until I get them up and running again.
Without publishing the page, it’s going to be hard for anyone here to help you out.
Have you looked at the console?
Hi Doug - I can’t publish the update with no maps. My clients site is for real estate developments and the maps and directions are critical. If I sync the update the maps will disappear. Still waiting to hear from Gary at Doobox.
Did you have a look at the console in the browser? It might give you a clue.
You could publish a test page without affecting the production page.
Assume you have an API key from Google?
I just tried Maps 2, If you don’t put in the api key you don’t get the Oops screen. I have a really old key and got the error.
I don’t use Google maps any longer so I don’t know if my key is good.
Hi Mark,
you are not alone ;o)
Same problem here … from time to time.
Without making any changes - sometimes the maps are there - sometimes not.
… have no idea why, either…
Did you check the console?
Seems like Google is always changing things on its map api.
Might give Open Street Maps a look. It’s open-source no key needed and no customer privacy concerns.
Yes. Same problem here too.
Map 2 had an update today.
If you want to preview maps you have to make some changes to Google.
Check out the release notes:
https://www.doobox.co.uk/appcasts/stacksReleaseNotes/doomap2_release_notes.html
I haven’t tried, just relaying the info.
For it! Excellent - many thanks to Gary ![]()
