Merging two rapid weaver projects
Is it possible to merge two rapid weaver projects?
Yes, open them both and simply drag the pages from one into the side pane of the other project.
What if one of the projects doesn’t open but you access the project files as a folder?
Is it the actual project or have you exported the website? If it is the project you could try duplicating it and renaming the folder with abc.rw as a suffix or abc.rw6 if you use RW6. If it’s an exported site then you would have to rebuild it!
