murray
(Murray Eisenberg)
January 23, 2017, 10:01pm
1
I seem to have multiple copies or versions of some stacks, some in
(1) ~/Library/Containers/com.realmacsoftware.rapidweaver/Data/Library/Application Support/RapidWeaver/Stacks
and others in
(2) ~/Library/Application\ Support/RapidWeaver/Stacks
All those in (2) are also in (1), either with the same date in (1) or a later date in (1).
Why the duplication?
teefers
(Doug Bennett)
January 23, 2017, 10:26pm
2
You upgraded from RW6.
Is your RW7 copy.
Is your RW6 copy.
They were moved in part to support user defined libraries:
http://rapidweavercommunity.com/tutorials/series/new-features-in-rapidweaver-7/episode/user-selectable-addons-folder
murray
(Murray Eisenberg)
January 23, 2017, 10:34pm
3
So there’s no reason to keep ~/Library/Application\ Support/RapidWeaver/Stacks, given that each stack there also is in the other location (in the same or later version), right?
teefers
(Doug Bennett)
January 23, 2017, 10:45pm
4
If you need to go back to RW6 for old project etc then they will need to be in that location. But RW7 will use the new location.
