Multiple issues with RW 8.1.3
Hi Tom
File is on the way. Its a large file
Thank you
File is 40MB. seems to big to email.
Any ideas to send to you
Best bet would be to use something like Dropbox, and Email a link to the file.
thank you
@gavtanner Thanks for sending your project in! I’ve taken a look and it appears that this is a problem with the RapidCart Pro plugin.
When you first opened the project with 8.1.3 I imagine you were presented with a window about missing resources, asking you to re-link them. If you re-linked the images and they’re all visible in RapidWeaver’s resource browser then it’s most likely a problem in RapidCart.
Have you contacted the developers of RapidCart about the problem?
Cheers
Hi Tom
Firstly thank you for looking at this for me.
After 2 days of work i have finally sorted this problem out. To resolve it i have installed RW8.1.4 and deleted every resource and re-linked them in the resources panel. I also had to remove all links in RapidCart to the resources and reinstate them as well. Then republished the complete website.
It appears to be back working ok but i am still going through thorough testing of every page to ensure all is ok.
Thanks again for your input.
Much appreciated
Gavin
Ah man that sounds laborious, I’m glad you got it working though!
It might be worth forwarding your project to the RapidCart devs just in case there is a problem at their end.
Cheers
Tom
