Hi, how can I best add multiple language meta tags to RW?
At the moment I add them into the page HEADER code section like: <meta name=“keywords” lang=“EN” content="performance …
Since the meta tags table only has “name” and “Content” columns I don’t know where to put the “lang” part. Any idea?
Your code isn’t showing.You need to highlight it and select </>. If you are using different languages, it is probably better to give language attributes to specific elements – div, span or what have you.
Not sure why the code didn’t show up:
<meta name="keywords" lang="EN" content="p...
That’s what I directly hack into the HEADER section because I can’t / don’t know where to enter the “lang” reference into the meta tags table(s).
anugyan
(Anugyan)
20 April 2016 11:54
4
Hi Rob, I have a multi lang site(ENG/DE) and am wondering how to metatag it. How did you proceed? could you give me a little help?
Anu
It might be better not to try adding multiple labguage meta tages. See here:
html, meta-tags
Can’t remember exactly, you can x-check here:
http://www.nlpp.ch and http://www.saphirion.com
Just take a look at the source code of the page and you should find it.
