Have a three column stack that I have a photo in the left column, a pdf file in the center and another photo on the right. I would like the ability to have the user zoom in the pdf and/or download the file. Any suggestions?
https://rwextras.com/zoomy/ will take care of the zoom.
add a link to the image to download?
How do I activate zoomy. It shows up in the add-ons.
it’s a stack, I assumed (mabe wrongly you were using a Stacks page?
I had to quit RW in order to see it. It is not really what I want though. It helps, but I would like to be able to let the user download a copy of the pdf.
Just give them a link to the pdf (that you have uploaded to your server).
If you mean like this - http://www.bromley-coppard.com/Bromleys/Bromleys.php - I used TopBox from Stacks4Stacks.
I set the content type to iFrame and then added a link to the PDF. As Scott says, you’ll have to upload the PDF to your web server first using an FTP program.
HTH
Rob
