New RapidWeaver project keep template from another project
Hi
I’m new to RapidWeaver and so far I really like it. The only issue I have is that in my test1 project I chosen a template and play around with it to learn the tool. I have deleted that project and now all new projects keep the same template and I don’t know why. I would like to start a new blank project with out that template. How can I fix this?
Thanks for your help
Benoit
Select another theme here:
Hi Jan
Thanks for your reply.
I know I can select another theme. My 2nd project it’s what I did and saved the project. But my 3rd test project still had the template of the 1st project. So my question is: Is it possible to start a blank project with no theme attached to it? I would like to design my own.
Many thanks
Benoit
Yes, check e. g. https://themeflood.com/blank/ or use a framework like Foundry…
Thank you very much. I really appreciate it.
I just downloaded it will play around with
Regards
Benoit
