Hi Brad, yes I did follow those instructions and in fact I had a RW5 project that I managed to complete in RW6. That project is fine and up and running. All my addons are up to date and it does show all my themes to be visible.
I’ll attached some screen shots so you can see. The first is when I try to open a new project, the second is when i open it showing the themes below, 3rd is when i try to preview this project, 4th is existing project which i started in RW5 but completed in RW6 showing themes and 5th preview.
Hope this helps as I can’t start any new project in RW6 for some reason?
Please advise if there is anything else i can do.
Thanks Brad,
this did it!! I’m so happy. I will try to get the update for Escape theme as well, but before i do i wouldn’t want it to mess up my other website when I go to edit it! Do you think it will?
Thanks so much again,.
Carla.
To me it looks like you duplicated the original Escape Theme (by the addition or{space1} is this correct?
If yes, a Theme update will have NO affect on sites made with that duplicated Theme…
If that is the actual Theme name for the V1.x of the Theme and you didn’t modify the Theme Source AT ALL, then there should be no issue with updating the Theme.
Michael David Design would be the one to ask though to make sure (I don’t know his handle on here) .
