misshedgehog
(Jayne Fletcher-Brander)
April 2, 2018, 8:23pm
1
HI
I published a website using RapidWeaver7
I have since made changes to the site and although RapidWeaver says that it has been re-published it has not
MacOS High Sierra / Version 10.13.3 / RapidWeaver 7
Fasthosts
N/A
FTP
At point of publishing
No
Unsure
Unable to complete
Would really appreciate you help. Thank you
swilliam
(scott williams)
April 2, 2018, 8:32pm
2
Try:
file menu
Republish All
Doobox
(Doobox Software)
April 2, 2018, 8:39pm
3
You say you made some changes…!
It’s possible if you are using Stacks, that you have added a stack to your page that converted your pages file extension from .html to .php
So if for example you were previously looking at your page at
www.someplace.com/index.html
and then you republished with a stack that converted the extension.
Looking again at
You’d see no changes.
Because you’d now be publishing a new page to
www.someplace.com/index.php
This catches people out from time to time and may be the case here.
misshedgehog
April 2, 2018, 10:10pm
4
Thanks for this but it unfortunately did not work. It is only publishing pre-changes.
misshedgehog
April 2, 2018, 10:15pm
5
Thanks for this advice. I literally just changes the colour of the font as it was white against a white background !!!
I changed the colour ofvthe font to black and now it won’t publish with the new font colour
I’ve tried the alternative publishing methods but they won’t publish it either.
Thanks anyway
Doobox
(Doobox Software)
April 2, 2018, 10:19pm
6
What is the URL?
Did you try visiting both .html and .php versions of the page after publishing?
Have you cleared your browser cache after publishing?
1611mac
(Greg Schneck)
April 3, 2018, 1:43pm
7
As Doobox says… clear your cache. A color change would likely be CSS and CSS is likely cached. Clear your browser cache and try again. When I’m working on sites I use a extension which clears the cache every time I view my page.
