Upgraded to RW6. Part of the upgrade was also upgrading RW5 to 5.4.1.
I have RW5.3.2 in the Application folder.
When I try to drag RW5.4.1 to the Application folder I get told that a newer version already exists and am asked if I’d like to replace it with the older version.
If you’re following you know that the thing is, what I’m dragging, 5.4.1, is newer.
Any ideas?
OS X doesn’t version-check. It uses date-of-creation. So, if some reason RW 5.3.2 is reported as being created on your Mac after the date of RapidWeaver 5.4.1, you’ll see this alert.
