Please provide a few details in the following format so we can help you as quickly as possible!
RapidWeaver Version:6.2.3 (14912) System Version:10.10.4 Hardware: 13-Inch MacBook Pro with Retina Display, 2.7GHz Processor, 128 GB SSD Storage, 8GB Memory.
Issue:
(Explain the issue here.)
With v6.2.3 changing one page causes RW to publish many, most, some times all, pages/files randomly.
Changing one page sometimes flags all or some pages as changed. And there is no global “mark all pages as unchanged” toggle so on a large site the process of “mark page as unchanged” each unchanged page is time-consuming. There is no way to select multiple pages at once and mark them as unchanged either.
Yes I have republished all files. No there is no Stacks v2 or v3 pages.
Expected Result:
(Explain what you think should of happened here.)
It would be so good to get this issue worked out once and for all.
Additional Links:
(If you have any projects files, screenshots or videos of the bug in action please link to them here.)
I noticed this too just recently. And since I’ve been running Stacks 3 for about a year – I’m going to make a wild guess that it’s not Stacks 3 (to be perfectly honest I don’t know that for a fact).
But I did notice there is a new settings was added to RW about the time this behavior cropped up. I posted about this coincidence here:
P.S. I’ve also submitted this bug to the folks at RMS – but it’s the weekend and as a favor to our friend Nik who had a tough week (https://twitter.com/nikf/status/637361661091934209) – let’s maybe let this one slide until Monday. thx
Thank you for the tip, Isaiah.
It is worth a try. I’ll post the results once this upload is finished.
As I am NOT running stacks on this large site and this has been a problem that has come and gone on various RW 6.x releases I have to agree that my suspicion is that is it is something they are (or really need to be) working on at RM.
When I searched the forums for info on how to “mark all pages as UNCHANGED”, I came to this topic. Seems like when I make a change to one page, suddenly several if not all pages get the “BLUE DOT”. I thought that there used to be a choice under Edit to mark page as “unchanged” but all I see now is “mark all pages as changed” and I don’t want to do that. In the Prefs for RW I have both “clear page status when exporting and publishing” checked.
Please correct this problem in RW7. I am using RW 6.3.7, Stacks 3.
When you add a new page, all pages are marked as changed.
When you change the name of a page, all pages are marked as changed.
When you edit the content in a page, nothing happens, only this page appears changed.
It’s all right, I think.
Any change that effects navigation will make all pages as changed, (adding a new page, change a page name) also if you are using partials, any change to a partial will mark any page that uses that partial as changed.
Yes @Oscar, all those things happen as they should but what I can’t find (and I’m sure it used to be a choice under edit), is to mark any or all pages as UNCHANGED. Has that option disappeared or am I not looking in the right place for it.
I don’t want to have to “republish all files” in order to get rid of the blue dots.
I am able to right click a ‘changed’ page and have the option to Mark as Unchanged. I don’t know that you can batch unchange a range of pages but one at a time seems to be an option.
In the file menu you can mark as changed / unchanged all pages and resources with one click.
Unchanged with the alt/option button when the file menu is open.
@Oscar
Thank you for reminding me about that option key thing. I tend to forget to think about that when I want to reverse something. It makes sense now. Leave it to the RW folks to make our wishes come true.
