Old fashioned navigation on the left hand side
I want to create a very clean website with an old fashioned navigation menu on the left hand side.
How to I adjust a theme or create this myself?
I have been digging trough the various settings and cant find it.
Thanks for your help!
Roger
Roger is this something you are looking to do? Www.sjolin.co.uk ? I used BWD Blueprint Sidebar stack to achieve this and has Font Awesome 5 icons by using SVG as icons?
Foundation has a way to do this, here is an example:
https://foundationstacks.com/samples/pillar/
Look at Will Woodgate’s themeflood.com. Lot of great themes options. Two of my favorites are Wilderness and Volcano.
Thank you all for the replies, I will check it out tomorrow.
You could also look at Paramount from Michael David as well as Blend from Weaverthemes.
Rob
So far I like Paramount best.
All the examples given present galleries of images. I have to see how well they look with text content.
Take a look at https://www.bachflowerremediesedinburgh.co.uk - that’s made with Paramount.
Rob
I would love specific details on how you did this… me like:)
