Can folks using RW 8.9.1 and and mac OS 10.12 - 10.14 please test this build loads ok?
https://yabdab.s3.us-east-1.amazonaws.com/downloads/FormLoom.rapidweaverplugin.4.0.15_old.zip
If not, then let me know what the error looks like?
HI, you may not remember me, I’m the guy who made the Paysnap template available last year.
I don’t have Formloom, but do run a 2010 iMac with the 10.12 OS for some old apps, that I can use to test things for you, if no one else comes forward.
@yabdab - I’m running 10.13.6 (until a new M1X comes out) with RW 8.9.1, Stacks 4.2.2, Formloom 4.0.15 (540) and get the following errors on the launch of my test project.
The first 2 are the errors, then the third screenshot shows the location of the plugin.
Fred
Thanks. That is what I needed to know.
If I hear back from @realmac or @tpbradley then I can see about how to build for older mac OS versions.
I too am now getting exactly the same errors as yourself.
Hello,
I’m running RapipWeaver 8.9.1 on Mac OS 10.11.6
When I install formloom I get the following notice
Same thing happened here.
The problem started a week ago with the addon installed on aug 17 (I can’t even remember I installed it, for I don’t use Formloom).
I tested again with the addon you provided in this tread with the known issue others have.
I run RW on High Sierra (OSX 10.13.6). iMac is a Mid 2010 27-inch.
Hope this info helps.
Hans
Something new on this topic?
Please test this version if using an old version of Mac OS.
This build should work on 10.12 and higher.
https://yabdab.s3.us-east-1.amazonaws.com/beta/FormLoom.rapidweaverplugin.4.0.15_b543.zip
A little bit off topic but I am trying my luck.
Was on Formloom 3 for long time. Bought FL 4 2 years ago, got problems. Went back to FL3.
Now I had to change to FL4 - and having problems again.
JSON parse error see screenshot
Site is
https://www.familienstellen-nuernberg.de/Anmeldung/
Opened a ticket with Mike - tried to get him access to my provider which didn’t work because I could only give him a sftp access.
Strange thing - it is working with one provider: Ionos – but not with two other providers: Strato and HostEurope
PHP versions all checked, all are minimum 7.3 which is what is recommended by Mike.
Can anyone shed some light on this cause? I am really tired of going back and forth with providers and Mike - after the not working try to give him ftp access I heard no more from him.
Perhaps a coder who knows Formloom and json very well…
Sorry, but these issues cost me a lot of time while I am trying to put up a working solution for my client.
Thanks in advance for any hints,
Tom
Sorry for not coming back to you earlier. It’s working fine with 10.13.6.
Hi YabDab,
Did not visit this forum since begin september. Installed the 4.0.15_b543 some minutes ago. I am on a MacPro3,1 under Macos HS 10.13.6 (dosdude).
The plugin installs with no problems en functions within RW 8.9.2 (20886)
greetings dirkV
MacPro 2010 3.33 6-Core
MacOS 10.14.6
RW 8.9.3
FL4 1.0.4
This plugin (4.0.1.5_b543) worked for me!
