I recently started using Google Fonts with Foundation. When using the paragraph stack I have no problem with the font being applied as long as I type directly into the paragraph text box. When I past text from say MS Word, the font formatting seems to get ignored even though I use shift+option+command+V to strip the formatting.
It worked.
I know that with your experience this was a simple task, but it means the world to us beginners out here and I sincerely appreciate your support and quick response.
