I am using pdf embed on the will Woodgate media theme and in Crome I get a PDF.js v2.2.228 (build: d7afb74a)
Message: Failed to fetch
error. It works great in safari. Any thoughts?
Works for meā¦is that @joeworkman PDF embed???
I like the top bar menu!!!
A question for @joeworkman Is that your stackā¦and if so, how do I get it to show that menuā¦I have ver 2.0.0 of your PDF Embed. Thanks
It is Joes stack!
It might be worth considering Willās own āEmbedā stack.
Is the PDF on your server? Iām trying to get Willās stack to work with a PDF hosted on Google Docs. I can get it to embed a Google Sheet, but not a PDF on my G Drive.
I put the pdfās in resources
Makes sense - I was hoping to embed a PDF that could be updated remotely. The people Iām building a site for donāt have Rapidweaver.
What was the URL to the PDF that you are trying to share off G Docs?
side note: You should not use spaces in your website urls. Use dashes in the folder names instead.
thanks, I have updated all the files
Hi Joe - https://drive.google.com/file/d/0B25LingV-LRcdDM5SjdOTGQ4aVU/view?usp=sharing
Regards
Barrie
Use the following url instead and it will work in PDF Embed.
Basically the trick is to put /preview at the end of the URL instead of /view
Thanks for that Joe ![]()
