Photo Patchwork
Hi Forum,
i want to create a Photography Site. I want on the peningpage a patchwork of little pictures side by side with no space inbetween. Also i would like to have the picture darkened when going with the mosuse over it. Also good would be a text showing when i rollover the picture.
Anybody knows if this is possible with Rapid Weaver?
Thx
K.
There’s lots of ways to do this if you have the Stacks 3 plugin.
Have a look at Gallery 3.
Or Montage 2 from Doobox.
Or maybe ProGallery from Stacks4Stacks.
Alternatively, go to Rapidweaver Central and search for Gallery there.
Take a look at Slider Eleven, it has many options for layouts that could fit your needs: http://archetypon.net/stacks/slider-eleven/index.html
Hallo, i am going crazy. I cannot get it managed to create a grid with for example 6 pictures in a line and maybe 20 lines. I want no space between the pics and the grid should go all the way to both ends of the page. Also a rollover with showing the name of the picture and zooms slightly into the pictures. Can anybody help me? Have RW7, Slider Eleven, Pro Gallery, Montage, etc. all running under Stacks 3 plugin?
Thx
K.
Which theme are you using?
Depart from the zoom into the thumbnail, this is possible with Gallery Stack 3 and it’s different grid possibilities
What do you mean with “depart from the zoom into the thumbnail”? I get really confused, all pictures are allways one below the other, no grid. Also, the Inspector Window looks always the same, it doesn´t matter what stacks i use. Anybody can help?
It sounds as though there’s a fundamental misunderstanding going on here. Are you able to publish anything so we can take a look?
Rob
I guess you are right and i do something totally wrong :frowning: I have nothing uploaded yet. Looks like there´s no way to show a screenshot as there is no possibility here to attach something. I start RW7, In the first window i go on “Create a new RW project”. Then a qindow appears that says: “Ooh, a new project,how exciting” and a blue button to some video series. Now i press the “+Add” button on the upper left. I choose “stacks”.From the stacks window i now choose “Gallery 3” and move/drag it into the “edit-window”…the edit window says: “drop stacks here”. The “edit-window” shows now two windows in a blue frame- one says “select grid/ slider +” and the other "add images or integration stacks. I choose “Justified” and “Photobox”. Now, whereever i drag pictures inside, in the review they are allways one beneath the other, no grid.
Thx
K.
Without published project, we are not able to help. But that sounds like an easy one.
If you have issues with Gallery Stack, open a request here:
OK. Try another step. Drag your images in - so they appear one beneath the other and then click the Preview button. What happens then?
Rob
