For years I have been using Rapidweaver 6 with no problems. Starting from scratch, it took me two weeks working full time to build a website. As I am doing my PhD I can’t afford the time to update my site to Version 8. And version 6 has been adequate up to now. Besides I think this may be a problem which occurs across versions.
What is happening is that I have made changes to my website in RapidWeaver 6 without problems. I can save the changes and I can Preview the changes. But when I check to see if the changes have been saved by checking out Safari, they haven’t been.
A good start…I was noticing on your site…you stopped naming your folders and just have Page xxx whatever…is that right or are those not the pages you are publishing?
Example: for the Deposit FAQ page: http://clarevillecats.com.au/page3/index.html
Sorry for not getting back to you earlier. I did a similar thing and asked the computer to search for “keychain”. To cut a long story short, I found that my iCloud did not have a password, which is the Apple password that password is no longer there. I have applied for a new password. Apple said it would be days before the new password comes. I think the computer can’t find the keyword because it isn’t there.
I waited to reply until I had a technician look at the computer. Thinking the problem was Version 6, I upgraded the site to Version 8, but the problem persisted. I want to reload Version 8 ready for someone else to look at it, because he made changes to the Version 8 code. The technician cost me hundreds of dollars and when I called him back because he had not solved the problems, the computer was worse. He got into the code and made changes.
How do I reload Version 8, so somebody else can work on the computer?
