Publishing problem after updating RapidWeaver to 6.2.4
I updated to 6.2.4 from 6.2.3 today and afterwards publishing failed on a site I’m developing. The file upload progression bar either stopped before completion, or I received this error message: ‘Can’t upload to your FTP server: Time out was reached’.
I still had 6.2.3 on my MacBook so copied the RapidWeaver project file and tried publishing from there, which was successful.
I then copied 6.2.3 from my MacBook to my iMac, having moved 6.2.4 to another folder, but publishing again failed with the same error as before. Perplexed, I powered down the iMac, rebooted, and then tried ‘republishing all files’ (over 1000), still using 6.2.3, and this succeeded. Subsequent re-publishing after changes to the site were also successful.
I’m now left wondering whether to try 6.2.4 again but thought I would see if anybody else has experienced any similar problems with 6.2.4 before doing so.
I had the same issue, but the second time I published it worked. I know we’ve been complaining about this prior to the latest update (http://community.realmacsoftware.com/t/rw-6-publishing-confusion/538/5) and RM said they were not able to fix the issues in time for today’s update but that they are working on it for the next update.
Thank you for updating me on this.
I’ve reinstated 6.2.4 and successfully published some minor changes. Admittedly these only involved a few files.
It seems, therefore, that it is an occasional glitch, which hopefully should be resolved in the next version.
Same problem with 6.2.3. I have just upgraded to 6.2.4 with no resolution. I still have to upload using an external ftp.
I tend to export locally and have found that images are not publishing at all since the upgrade. Is there a way I can easily revert to an older version of RW at all? Wasn’t having any problems with 6.2.3!
Edit: Tried another file and it seems to be content on Blocks pages which are not publishing; which is not great for a project which is using the plugin a lot! …
Just downloaded 6.2.3 and it’s made little difference, next stop YourHead!
“Time Out Reached” is an error message from your server. It might be worth lowering the number of concurrent publishing connections in the RW Preferences.
—N
