So please If someone knows how to solve this will be great, because 1LD takes so long to answer.
Multiple Input Field Short-Codes
When you want to create a short code for an input field value that comes from a slide with multiple Answer Types , you will need to reference which value you want to use by adding a dash (-) followed by a number representing it’s placement order. For example, If I had two input fields and one text field in a single slide, and I wanted to get the value from the second input field, my resulting short-code would be
[slide3-2]
