Question for Siphon users
I have a support ticket into 1LD but curious if anyone knows the answer in the meantime.
I have a form setup and it all working great. However, I’m trying to get the custom email to work and I can’t seem to get it to return the results for the Siphon slide that has Checkbox/Radio as the answer option.
So, the slide is set to q3 as it’s ID. I’ve tried [q3] in my email form. I’ve also tried [q3-1][q3-2][q3-3][q3-4][q3-5][q3-6] for each of the 6 options but the email still shows up blank for that question (the other questions show up as expected).
Just curious if others have successfully done this and if I am missing something.
EDIT: Thought I should update this in case others find it. 1LD responded that there is an update coming that will fix this.
Hi jabostick,
I’m having the same problem here and I don’t know what to do. I wrote today to 1LD so they can fix my problem. I hope it has a solution.
The site where I had this issue has since been discontinued so i can’t check if it was fixed or if I modified the form. The original issue was an unfinished feature accidentally made it into the update but I can’t find any release notes though to suggest if it was fixed… @1LittleDesigner
It is a real shame, I bought siphon hopping to solve all these questionnaires problems and all was perfect until the checkbox problem, so I have a lot of unanswered questions on my mail.
