I want to set up one page that contains two Progallery thumbnail groups, each of which plays a separate slideshow. I plan to put some text between the two thumbnail groups. Does anyone know if this is possible, and if so, how it is done?
Sure. I used Adaptive Grid: https://stacks4stacks.com/adaptivegrid/, then put a ProGallery Stack in each grid cell. You can also put text in one cell inbetween the two slide shows.
A couple of samples:
https://lisasandlerphotography.com/portfolios/events/
https://lisasandlerphotography.com/portfolios/film-advertising-design/
Well I’m still struggling. I have put a ProGallery stack in each of two Adaptive Grid cells - for testing purposes they are copies of the same stack. The Thumbnail group is generated correctly for each, and the first slideshow works normally. But the second won’t work - I just get separate images. You can see it here: http://ianburden.com/page-15/page-35/
Any clues?
I can tell you without looking… You have to name each gallery ID differently.
No, I tried that. They do have different ID’s. One is called “Going south” and the other, “Going north”
Do they have spaces like you just typed? If so, try a dash with no space, that could cause issues.
lower case, with a - between each word? You need that. Like my screenshot.
Bingo! Thanks for the coaching.
Yay!!! Happy to help.
