I’m using an old version 4.3.1, and suddenly the publish button is greyed out. Help!
That’s usually a result of no changes being made. Can you try making a change in your document - does that publish button still show greyed out?
Is your publishing info all entered in settings?
By the way, we’re at RapidWeaver 8 now. Would love to get you up to date.
Actually I was making a change, accidentally deleted the path info and had to re-input, then made changes. The changes were “saved” but no publish button.
And yes, I believe all the publishing info is there.
So, no other suggestions?
