Rapid Weaver 7 Blog Question
Is there a way to import your pictures into RW7 Blog easier? than a resource line format that I was told to use, I put it in here but it tried to use the resource lol.
The RW7 blog is good enough for what i need, however i find it a pain putting my picture’s in, is there an easier way, that works like RW7 Blog and fits right in the same idea frame work?
Just drag and drop works for me!
When i did that it seems the size of the photo was to big? did you size them however?
You can do, double click to change size but it’s better to use the ImageMini App (or similar) first.
wow! I did not know that! Thanks a bunch!!! lol…learning something everyday on RW…I’m new if you cannot tell…lol
