I need some CSS code please, (if possible) to move the RapidCart Option Product button.
I’ve managed to move the cart button with some CSS, whoopee! (I’m a novice!) Not sure if it will transfer ok when it is published yet.
I have been referred to the RapidCart Pro, it’s manual, and project, and have keenly read these, but have already set up my project in RapidCart and just need the option button moved, CSS instructions for moving it up, and across (right) would be great! Who can help!!! please!
I have @imported an image and description. I haven’t dropped the image into any of RapidCart set up pages, but the option button, and cart are ready.
Oh, ok, you are talking about RapidCart 3, not RapidCart Pro.
Please send me the link to a test page and tell me where you would like to move options.
I’ll tell you how to achieve it with a Custom Layout or a CSS rule.
I’d like ‘size’ options button moved over to the right, 2 spaces under 'certificate of authenticity. The ‘s’ of ‘size’ under the ‘c’ of 'certificate.
I would also like the ‘add to cart’ button in line with the edge of the image. The price above.
I have had a reply ‘You can enable Custom Layout in Page Options > Style window and change default HTML code for product row.’ But I still don’t know how to do this, (and I have tried!!!)
Sorry for my late reply.
As far as I can see, you composed the product page with Stacks and import the RapidCart part with PlusKit.
In order to move the RapidCart part below your custom description you need to move the corresponding stack on the right position.
