RapidCart plugin missing
I’ve been using RapidWeaver 8 and RapidCart Pro with no problem since the update to RW 8. Suddenly today, when I open RapidWeaver, I get a message that the RapidCart Pro plugin is missing. The Store page does not load. I have tried re-downloading and installing RapidCart Pro, but that does not help.
I have no clue as to what the problem might be and would value any advice.
Same here, see message I get. I can no longer update my store!!!
Roberto from help@4gnd.com has contacted me to say they know about the issue and are investigating.
I have used RCP with RW8 with no problem, so I do not know why this has arisen in the last day or so.
I am seeing the Rapidcart thing as well with the current RC candidate.
I have this problem as well!!!
Yesterday it was fine, and I did no SW updates and of sudden this happened.
I tried to re-install. and even tried on another computer and still not working.
The problem has been fixed.
Just download the update we have just released.
@rob Was that problem only on RW 8, or should RW 7 users also use this new version?
All versions affected.
thank you!
