RapidCart Pro Failing Login at startup
I don’t know if someone already fix this but is kind of annoying and frustrating having to deal with this every time you start Rapidweaver
Apple Silicon requires RapidCart Pro, which is currently in beta.
You can download it here.
I have Rapidcart Pro. what do you mean? a newer version?
I think what is meant is that the only version of RapidCart that is compatible with M1 is a Beta version of Rapidcart Pro - this won’t have been publicly released as it’s a Beta version. You can download and try with your M1 Mac although as a Beta there will obviously be no guarantees that it is 100% bug free. Despite all this you should be able to use Rosetta?
Rosetta is installed by default. Works good tho. The beta has been installed and now I don’t have that annoying pop up window anymore. Hope it doesn’t affect my client store
